Question electrolytic capacitor from 1990`s
This topic is closed.
Re: Question electrolytic capacitor from 1990`s
it takes very many years to depolarise a standard cap - your being fearmongered by assholes on other forums.
the type of equipment where we need to worry about such stuff is from the 1970's or olderComment
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Ignoring the missing "l" (adjacent key errors are my frequent typo type), polarized (= normal) electrolytic capacitors don't depolarize. Very long non-use might lead to the aluminum oxide dielectric layer thinning (probably years of non-use, possibly excepting some cap types with water-based electrolytes), decreasing the voltage the part can withstand, but depolarization won't happen. Being polarized is part of the nature of an aluminum oxide layer dielectric.... electrolytic capacitors will ... depoarize ...PeteS in CA
****************************Comment
Electronic devices that use electrolytic capacitors from the early 90's need to be turned on at what frequency of time interval to prevent failures from disuse? i have crt tv, snes, megadrive, ps2 slim, power supply
not are new capacitors are capacitors 90sComment
And in 1986, these electrolytic capacitors were no longer new and it is necessary to do what the instructions recommend.Comment
This thread is closed. See attached txt file for the reason why.Attached FilesComment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
by AleXis6Guys. could you help me please to decode some codes of main capacitor's producers.
I would like to know the manufacturing date.
Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
If I understood correctly:
1. Nichicons marks date of production as (see the attached pictures) H2116
I don't understand the meaning of first letter - may be it is code of factory.
21 -year
16 week
I bought this capacitor recently.
another one-
2....-
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by beogeekHi all,
I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally
, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
Cheerio...-
- Loading...
